V-Power sucks!
I just started running shell in my 88 ranger and it's getting better mpg noe then any other fuel i tried... Going to stick with it... Won't try v-power though, waste of money on this thing lol
V-Power Racing does well in my turbo (turbo susceptible to fuel quality) and I just put first tankful in BMW yesterday. V-Power currently out of stock here so BP Ultimate 98 RON for the Outback, good fuel anyway imo.
Originally Posted By: Pablo
V-power does nothing for my engines.
Same here. I have seen really poor MPG in my vehicles with it compared to other brands in this area. Shell around here, tied with Mobil, is the most expensive brand as well.
V-Power sucks all right!!! So is the price per gallon which is $4.00 bucks just for 87. What a rip!
Durango
Vpower up here in Canada seems to be the only fuel that contains NO ETHANOL.
Thus I get much better mileage on my cars (07 acura rdx and 99 honda prelude)
I just ran a bottle of Slick50 and vpower in my prelude will see how much better my mpg gets.
Power wise seems good.
I put Shell Premium in my ethanol test tube after a 1 gallon draw to eliminate unknown hose content and it was both E10 and yellow. BP/Amoco Premium I get E10 and clear. No Shell for me.
What is an ethanol test tube? What is the implication of the yellow color? Both were E10, right?
where can i get this test ?
I'd love to test fuel around here.
As of either March or May 1, 2008 all grades of auto gas in Michigan is minimum E10 apparently required by the EPA. Mobil regular gas is clear E10 also. Refineries selling to each other makes it hard to distinguish brands unless maybe they are careful about who they complement with.
LaPointe mentioned the tester in one of his articles and I immediately went to eBay to find it. Mileage testing is easier when you don't need to play guess-the-chemical in your gasoline. Search eBay for "tester alcohol fuel". That's a small one so it requires some effort to keep it accurate but it works fine. You could do an Ethanol presence test with any test tube since any rise in the "water" level means there is some Ethanol. These tubes provide calibrated lines so you know what the percentage is by following simple instructions on the test tube. This tube measures E0 to E85.
Filling the test tube is quite easy after you've found all the ways to do it wrong. I carry around one of those high pollutin' water bottles and the water line is almost exactly a cap full. I pump gas into my tank until the shared hose is clear of the previous gas. Then I stop and withdraw the pump handle until I can tilt it upwards with it still in the filler neck then kerchunck the trigger. This fills the spout with enough fuel to pour and any that squirts out goes into the tank. By buying one gallon from each gas station you can test a bunch in short order.
Boaters don't want alcohol in tanks for any reason. You can help them find ethanol free gasoline and maybe get a few free boat rides. Airplane operators with an autogas supplemental type certificate may be buying under the assumption that E-anything would be labeled. E10 or less does not need to be labeled at the pump in Michigan. Sounds like free gas for the mechanic.
http://www.fuel-testers.com/
That's one with a bleed tool for airplanes. Any airplane mechanic should have this.
http://www.e10sucks.com/
You can see how it works and see a very accurate one up to E30 in this video.
After shaking the "gasoline" is not pure. Some ethanol and water stays in it so don't pour it into your tank for disposal. I pour it into my intake. That burns it up without polluting my tank.
It's already a novelty item here in Michigan thanks to our incompetent politicians. Word was that many premiums were Ethanol free but a trucker told me that as of March or May 1, 2008 no trucker can deliver any grade of gasoline less than E10. Fortunately I have found a nearby premium tank with no Ethanol so I'll be buying that until one of us runs out. If we ever get some reprieve from this Ethanol blending boondoggle I'll be able to find the first station without it.
Google Results for Yellowish Hue to Gasoline causing varnish and deposits
AOL Autos: Does gas go bad?
BP Advertisement for Crystal Clear Purity
That's exactly how it looks except that mine has a water line.
Until the Shell gas additive package is ruled out as the source of the yellow color, I cannot accept that it's yellow color is a sign that it's inferior to clear gasolines. I'm all ears.
That sounds easy with repeated testing. The additive quality and quantity should be consistent from batch to batch. The base gasoline where the "bad yellow" comes from should vary.
The "bad yellow" may not be a problem if there is sufficient additives to cover it. I'm avoiding Shell because all the gas is the same price and the yellow color as a potential problem is a as good of lame excuse as any other.
I thought all gasoline is clear as refined and any color is identification dye added at the refinery. I've seen pink and red gas too.
Drew
Filled the BMW with V-Power Racing tonight cost $102. Sensational fuel. I saw 5.7 litres per 100kms on the computer on the way back into town after fill up. Imagine how good it will be after I replace the [censored] blocked K&N and 76,000km old plugs?
