Schaeffers 9000 CJ 11.2k uoa 03Cummins
lllinois
3500 o3 Dodge Cummins 129,600 on engine 11.2 on oil
1st column 4.5k on unknown oil with a decent amount of neutra.
2nd column 6.2 on oil. had one quart make-up, 1 pint moly ep 132, and 200 mile prior to change 5 oz of neutra. Schaeffers ci 4 15-40
3rd column. 11.2 on oil. No make-up oil, no additives. 5k of heavy towing. Schaeffers 9000 5-40 cj
Copper 71,22,43
Fe 150, 57, 57
Chrom 7,3,3
Alum 37,23,18
Lead 16,12,15
Moly 64,326,466
Phos 1740,1394,1411
Zinc 1864,1627,1757
Mag 756, 93, 1079
Calc 3803, 3948, 2068
Silicon uk, 18, 23
Pot 0,1,1
All contaminants nil
Visc 15.33,16.32, 17.37
What kind of condition is the engine in, and what kind of usage as per routine operation? Those are some high wear numbers (all around) there...high silicon too. But those Moly and Zinc numbers are nice- are those from the moly ep additive?
"But those Moly and Zinc numbers are nice- are those from the moly ep additive?"
No. That was a fill ago. The moly and zinc would be from 700 and 9000.
salesrep - those are some strange figures. - look at the Mg ?. Ca seems low for S9000. I hope you will run S9000 three OCI's so we can see a better picture of the additive levels.
