weld leaking on transmission pan.
by motor_oil_madman
02/07/16 03:41 PM
PP and Honda CR-V
by klt1986
02/07/16 03:04 PM
113,800 miles on plugs w/ pics - 2009 F150 5.4 3V
by 04SE
02/07/16 02:59 PM
Sludged 1zz-fe pic... Ex-fleet car.
by SanProsan
02/07/16 02:53 PM
Autozone oil score today
by jdavis
02/07/16 01:12 PM
Valvoline V0-88, 5,000 miles, CUT OPEN
by car51
02/07/16 12:27 PM
Timken throwout bearings?
by buck91
02/07/16 12:17 PM
Whole house water filtration types of set ups
by oilboy123
02/07/16 11:54 AM
QS Defy is now QS"high mileage"
by hjones
02/07/16 11:47 AM
TGMO came out reddish
by chiefsfan1
02/07/16 11:41 AM
Run Oversized Fram Ultra 25k & Multiple OCIs
by WillsYoda
02/07/16 11:35 AM
Rislone Zinc Additive
by hjones
02/07/16 11:34 AM
Compignite, pezman65, Wansu, DaleAZ, Nazmorgul
56846 Registered Users
108 registered (901Memphis, AndyB, 2015_PSD, ABerns, 04SE, 9 invisible), 1744 Guests and 192 Spiders online.
56846 Members
66 Forums
244375 Topics
Page 1 of 3 1 2 3 >
#1150528 - 05/13/08 04:13 PM Isuzu 4BD1_Amsoil 15w40
Shup1 Offline
Loc: West Coast Florida
Enclosed are the results from 325 hour run of Amsoil 15w40, this unit has run Delo / Rotella T & LOS since new, unit was flushed with Auto RX for 250 hours. Filters are WIX (air & oil) with off road diesel and Power service or CRC (which ever the farm has on the shelf).
Thoughts....
2006 Dodge 2500 CTD / 2007 Chrysler 300 / 2009 Mailbu / 93 F-150 (185k miles and no synthetic oil, bypass filter and it still runs)
#1150541 - 05/13/08 04:37 PM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Shup1]
Shannow Offline
Loc: Oz
Looks good.
Nissan TD - Edge 5W30 A3/B4
L67 3.8 - Magnatec Stop Start 10W30
Mower - M1 5W50 with Rislone
#1150550 - 05/13/08 04:46 PM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Shup1]
tdi-rick Offline
Loc: the antipodes
Love the 4BD1 and the 4BD1-T.
These things go forever.
I'm guessing this is in a generator ?
These engines were used in the mid-late eighties in Land Rover 110's (Defender) in Australia, and it's still considered the best engine Land Rover has ever fitted to a vehicle.
I didn't realise Amsoil used that high a calcium level, as Japanese diesel manufacturers typically call for Ca levels of 3000ppm+, so that's a plus.
Land Rover.
Helping put oil back in the ground for 60 years.
You can't get any greener than that......
#1150572 - 05/13/08 05:20 PM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Shup1]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Basically looks like virgin oil in the wear department.
Everything else is perfect.
A certain guy in the diesel forum seems to think Amsoil produces high Fe. Doubt he'll post here.
#1150595 - 05/13/08 05:41 PM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Pablo]
Gary Allan Offline
Loc: Pottstown, PA
How long are you going to run next OCI? You've got noise ..and low noise at that. This is great. Amsoil diesel oils get little love. It's probably more due to the difficulty most have in doing longer drains.
Did you happen to cut open your Auto-Rx filters? Are you using the maintenance dose?
http://lube-direct.com/gallan/
#1150605 - 05/13/08 06:08 PM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Gary Allan]
Shup1 Offline
What you must remember is that this motor has over 9000 hours on it already, I figure that is about 450k in road miles with little or no rpm changes (2k consistant). So for the readings and age I believe it looks pretty darn good, the oil is still a amber colour (slightly dirty now) but I see no nbeed to add a bypass.
The Auto RX filter change was after first 10 hours, no gunk or buildup...then went an additional 200 / 210 hours with no visible gunk or buildup ( I even checked the used oil and it was not bad). I am not running a maintenance dose due to simple economics, I may however do a treatment every other year??
I hope to get another 325 hours, if so that will extend oil change almost twice....at $3.80/gal for off road it is money in the bank.
I also have this same oil for 2006 CTD..anxious to see results
Edited by Shup1 (05/13/08 06:15 PM)
#1150870 - 05/14/08 01:31 AM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Shup1]
pickled Offline
Loc: The Rocky Mountains
Let's face it...Amsoil AME is a rock star for the price! If you can sign up for a commercial account with Amsoil it is pretty darn inexpensive for the performance.
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
#1151011 - 05/14/08 08:38 AM Re: Isuzu 4BD1_Amsoil 15w40 [Re: pickled]
LateArrivalforLSU Offline
Loc: Louisiana
Good gosh, what a great looking UOA.
- 2008 Chevy 2500 HD
- LMM Duramax and Allison
- Flo~Pro Turbo Back & EFI Live
- 40 ft. Keystone Avalanche 5th Wheel
#1151022 - 05/14/08 08:55 AM Re: Isuzu 4BD1_Amsoil 15w40 [Re: LateArrivalforLSU]
-Clayton- Offline
Loc: KY
Awesome!
1985 F250 Ex-Cab 6.9 C6
2002 Dodge Caravan
#1151032 - 05/14/08 09:06 AM Re: Isuzu 4BD1_Amsoil 15w40 [Re: -Clayton-]
Harley Anderson Offline
Loc: State College, PA
Amazing uoa, just goes to show you what is the easiest service on a motor and oil. At 325 hrs with my average speed being 39.8 this would be like a uoa with almsot 13k miles on it. I would think 12-1400 hrs wouldn't be out of hand with some makeup oil along the way.
2005 Dodge Ram 2500, CTD, NV5600, Frantz BP Filter, Baldwin Coolant Filter, Amsoiled.
#1151040 - 05/14/08 09:18 AM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Harley Anderson]
pickled Offline
Add a bypass filter and his grandkids might be the next ones to change the oil...
#1152581 - 05/16/08 09:35 AM Re: Isuzu 4BD1_Amsoil 15w40 [Re: pickled]
Shup1 Offline
pickled...I thought about it but with the setup on this motor it would leave opening for mice and critters to enter the area...
The oil appears very clean, this motor setrup does not turn the oil black like the newer versions, as you see the soot level was nil and I will probably do a particle count next time for giggles...
#1152628 - 05/16/08 10:41 AM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Pablo]
D-Roc Offline
Loc: quelque part
Possibly they got the sample mistaken for a virgin sample of AME at the lab...
Edited by D-Roc (05/16/08 10:48 AM)
#1152769 - 05/16/08 02:22 PM Re: Isuzu 4BD1_Amsoil 15w40 [Re: D-Roc]
Shup1 Offline
Hard to miss my samples...They are usually labeled well.
stirring the pot are you?
#1154093 - 05/18/08 08:49 PM Re: Isuzu 4BD1_Amsoil 15w40 [Re: Harley Anderson]
wjdell Offline
Loc: Florida
I think that has to be a record UOA. 325 hours thats about 13k miles for me. If its a GENSET running under a consistent load that would explain the UOA. If it has a by pass system then the wear was probably a bit higher than the UOA would indicate. Which double nothing is still nothing. I take thats AME 15W40, that is a good oil. I have seen things can kinda flip quickly so be careful and good luck. I am leaving my oil in my GENSET two years, it probably could go three years.
Page 1 of 3 1 2 3 >
