Thanks for all the replys.
Here's a link to a UOA I did before this one:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=803874#Post803874
Same lab.
Both show lowered flashpoint.
The 9000 rpm redline engine in the S2000 is known for using oil, especially the early model years.
Most of them use oil because (IMO) the oil was changed too soon when new and synthetics were used too soon, the manual cleary states to use dino (factory fill) for the first regular schedule OCI, being 10k km.
I bought mine with 80k on the clock, 3rd owner so I don't know how it was treated.
TBN of the 0W-40 was high, 10.xx, probably also due to make-up oil.
Oil usage dropped but the OCI almost doubled, looking at it that way the make-up oil isn't that bad.
Its worse to have no oil
The Pb levels are too high?
Pb = crankshaft & piston rod bearings right?
Compared to the 0W-40 (per 1000 km) its about 3 times as high.
Same K&N was used with the 0W-40.
Maybe I should stick to 15k km OCI's
