Schaeffer 9000 5w40 2003 Dodge Ram 5000 mile UOA
Colorado
I pulled an early sample this time to look for antifreeze/water. I'm worried about a possible small coolant leak. Potassium still seems a little high in this sample.
Miles on oil:
5000 - - 14025 - -Avg on Unit
Make up oil 0qt - - 1qt
Sample Date 4/22/08- -2/1/08
Aluminum .....4.........4........4
Chromium......0.........1........1
Iron..........9........14.......12
Copper........6........10........8
Lead..........2.........4........3
Tin...........2.........1........0
Moly........251.......232......242
Nickel........0.........0........0
Manganese.....0.........0........0
Silver........0.........1........1
Titanium......0.........0........0
Potassium.....9........18.......14
Silicon.......6.........5........6
Sodium........6.........4........5
Calcium....3118......3164.....3141
Magnesium....10........27.......19
Phosphorous.1030.....1090.....1060
Zinc.......1176......1335.....1256
Barium........0.........0........0
Sus [email protected]
cST [email protected]
Flashpoint....440.......430.....>410
Fuel.......... Insoluables...0.1.......0.2..... TBN...........8.6.......0.9
-john
I saw your post on TDR. Did the oil test positive for coolant? Try pming wwilson on here and see if he is any help. I remember he had some problems with his 04 with coolant in the oil a while back.
I do not believe you have a coolant leak. I think you are in great shape. 14k may be a bit high for a OCI and that is what you are seeing. Stick to one oil do not flip flop from oil to oil. Cu is a bit high but I am seeing other engines jump in Cu using S9000. This may be in the oil and a VOA will show it. You also could use a lab that covers Antimony, and as well soot level. Insolubles and soot are not quite the same.
I had Terry run a sample at 10k (between the 2 reports I list above). It has Antimony, KF, soot, and glycol...
Iron: 16
Copper: 14
Tin: 0
Lead: 5
Chromium: 1
Nickel: 0
Alum: 6
Titan: 0
Silver: 1
Calcium: 2493
Magnesium: 45
Zinc: 1491
Phosphorus: 1220
Barium: 0
Moly: 282
Antimony: 34
Silicon: 6
Sodium: 8
Boron: 8
Potassium: 6
Vanadium: 0
OXID: 15
NIT: 6
KF: 903
TBN: 7.5
FUEL: 0.00
SOOT: 0
GLYCOL: 0.06
Thanks,
-john
Did you add a oil cooler - I do not know allot about that engine - what does Terry think about your Cu. Don't often see Silver counts. But other than the Cu of probably 12, it sure looks good to me.
