Originally Posted By: badtlc
Idemitsu makes a rotary engine racing full synthetic rotary engine oil (PAO & Esters)
http://www.idemitsu-usa.com/page_211.htm
Might give it a try.
Thanks, I've heard of it. Some do use it. I've also heard that Mazda co-developed it.
As far as using synthetics in the modern rotaries (not sure how to define modern, but surely the one I have), I'm pretty sure that many are using it with success. Having said that, I don't know the long term benefits or problems with using it in the Renesis. Those that use it tend to be the type that run their cars pretty hard and they don't seem to put many miles on them.
Also, some RX8 high performance companies use it, and recommend it for extreme cases (racing etc). Others don't recommend it exclusively citing the obvious differences between a daily driver and a racing engine. Some recommend it exclusively, with much heavier weights (20w-50 for example) regardless of the cars application...racing vs. daily driver.
Many argue about it on the RX8 related sites.
My car being a daily driver, well sort of, will not have its engine torn down regularly so those differences between the racers and the daily drivers are applicable to me. And this is why I'm sticking with a majorly GRPIII oil like Amsoil XL, Pennzoil Platinum or the yellow bottle Pennzoil (is it 60% GRPIII). I'll be changing it at 3k miles regardles of what I use.
The long and short of it is Mazda doesn't not recommend using it. They don't prohibit it, it's just not recommended and they qualify their position with "synthetics are not recommended since Mazda has not done any long term studies where it has been used".
Having said all that, with GRPIII being considered synthetic, and the Mazda recommended weight of 5w-20, nearly all of which have some GRPIII in them...what exactly is Mazda recommending. No PAO?
They seem to be talking out of both sides of their mouths, perhaps looking for reasons to not warrant or limit the warranties of these engines.
They seem to be subject to a higher failure rate than the a typical gaosoline piston engine sold in most cars today, most of which appears to be due to apex seal failure (analogous to piston rings).
Ok, I'm finished blabbering.
