I'm reeeeaaaally getting tired of Mobil's monkeying with their product line. The Delvac-1 formula is now "Delvac-1 ESP", with a CJ-4 rating. Click here for a photo of the jug and some more info. And, the Mobil-1 5W-40 "Turbo Diesel Truck" oil has also changed, it's got a spiffy new label on the bottle, and is also CJ-4 rated. Click here to see Mobil's website info, or click here for the data sheet.
I called Mobil and asked if the two were the same. Answer: No. They are NOT the same formula. The tech was unhelpful and didn't elaborate. And at first he didn't even know the M-1 TDT was reformulated, I had to convince him that I was looking at a new bottle with new ratings! D'oh!
Anyway, up until recently, the M-1 TDT oil was identical to the (original) Delvac-1 oil... same formula, same oil, same CI-4 rating, different bottle. But that is no longer the case. If you are wondering what "ESP" stands for, it's "Emissions System Protection", where they have removed (or reduced) certain additives from the oil. Click here for more details. FWIW, I don't plan to use any ESP oils in my older (80's and 90's) engines.
Just curious, does anyone know exactly what changed with the CJ-4 formula? Specifically, which additives were increased, reduced, added, or removed? The data sheet indicates that the phosphorus levels dropped (click here for the Jan-2007 spec sheet, click here for the current Dec-2007 spec sheet.) But that's about all I can find.
