""would the use of high quality chlorinated adds be useful for say the 1000 miles or so that it takes for the break in to happen""
I would about garrantee the compared equal % wt the Chlor will beat the ZDDP on anti scuff and load carrying ability big time.
But as discussed before metal corrosion/stain/seal problems/sludge etc with a chlor parrifiin may negate any improvement.
Bur I have always thought that if you used a CP at say 1-2% or
about 6,000ppm to 12,000ppm that it would be a great wear reducer provided you dumped the oil at a short interval to avoid any of the known problems, with the chlor still "attached" to the metal the wear reducetion improvement "effect" may last a a while.
I do not know what effect additives/film formers have on "break in" they may stop the process.
bruce
