1999 Honda ST1100
Water-cooled V4
Shared engine/trans. oil, wet clutch
Comments:
Valvoline Max Life 10W40 oil
1536 is a Napa Gold automotive oil filter
No oil additives used. FP3000 in the gas.
The Max life sheered down but the wear numbers look pretty good.
This will be the last oil test for a while. I started an AutoRx treatment with this oil change.
The compression was identical on all 4 cylinders so I don't expect to see a change.
Blackstone Labs Test results:
Oil...............GC0W30.........Honda 10W40 Rotella 15W40 CJ4 ....Max Life 10W40
Filter............3423 Bosch.....1536 Napa Gold....1536 Napa Gold....1536 Napa Gold
Total Miles....73,008...........81,081...........89,028.................97,045
Miles on oil....7,975.............8,073.............7,947..................8,017
Time on Oil.....5 1/2 mo........4 Mo...........3 Mo.....................5 Mo
Make up oil......0................0....................0.....................0
Aluminum.........13...............12..................13...................9
Chromium.........1................1...................1.....................0
Iron................41..............25..............24........................23
Copper............4................3................3.........................3
Lead...............2................3................4........................3
Tin.................0................1................0.......................0
Moly..............36..............50..............8..........................249
Nickel.............0................1................0........................0
Manganese......1.................0.................0.......................0
Silver..............0...............0...............0.........................0
Titanium..........0................0................0.......................0
Potassium........3................2................7.......................2
Boron..............11.............124.............32......................13
Silicon.............14.............12.............12.......................12
Sodium.............175...........58...........19........................10
Calcium............2290.........1988.........2347......................2588
Magnesium........456...........65...........17..........................9
Phosphorus.......906..........815..........956........................742
Zinc.................1140.........1053.........1264....................863
Barium.............0..............0..............0.......................0
Flashpoint F......410...........390...........400.....................385
Fuel................ Antifreeze........0.35..........?..........0............................0
Water.............0..............0..............0........................0
Insoluables......0.3...........0.2...........0.2.......................0.2
SUS Visc@210f..60.3.........60.8.........71.5......................61.5
cST Visc@100c..10.29........10.45........13.35...................10.64
TBN.................7.2...........3.6...........4.2...................3.1
Water-cooled V4
Comments:
