Ok well I did the complete brake job successfully. Now it's time to tackle the spark plugs. I see from my Haines Manual that I need to remove the upper intake manifold and maybe even the throttle body. Has anyone done this on this engine? What are the pitfalls and things to watch out for? I assume I'll need a new intake gasket ( should I use sealer?)and I have the correct factory plugs. There is also a water transfer rubber hose under the cover that I should replace as well while I am in there. Any other advice? Also I can't find the torque specs for the intake manifold.
Any advice would be very much appreciated...
