My saab has a swuare pad on the top of its scissor jack. The square pad inserts into a square receiver on the body of the car - I suppose it is reinforced there.
I got a HD 2-ton jack, not the chinese cheapo ones. Its got a BIG lifting area, so I cut a 2x4 to fit the square on the car, sat that on the jack surface, and pushed up the car to change out my winter tires yesterday. Worked like a champ.
However, my BMW doesnt have such a surface for pushing up. The OE jack effectively clips to the little welded point in the unibody, and then pushes up on one side. I assume that this is why the adapter linked above has the gap:
It seems to me that in the picture, the device isnt being used properly... It seems that the gap between the two sides should be where the welded metal that sticks down from the unibody goes, and then the adapter pushes up from the jack to the body, but not on the welded, thin strip.
I used a block of wood between the jack and frame points known to be good to use with a floor jack. Worked fine, however this seems to be a nicer way...
Am I wrong?
JMH
