mom has a new A4 2.0T FSI (4k miles on it). i know all of the dillution problems with this engine. i've read most of RI_RS4's threads. STFA a bit already and read the other 502 threads. i will be doing 5k intervals (if i can make it home to change it).
She mainly does short trips. I'd imagine she's not too demanding on the turbo but at the same rate probably doesn't worry too much about getting the engine up to operating temps.
seems like the 5w40 syntec is pretty blah for the money. Not real thrilled about the mobil 0w40. i just have a love affair with 5w40s, what can i say. so i guess i'm leaning towards the pentosin pento high.
The disadvantage to the pentosin, i have to mail order it, and it's a little more expensive. I can also find Elf Excellium DID 5w40 but it's even more expensive. pento products are often factory fill for VAG cars too btw.
not looking for huge conversation, rather a quick suggestion. i want to stick with 502 for warranty purposes. Our dealer is sh1t and will throw us under the bus immediately if there is an engine problem and no spec oil in the pan.
my TT and S4 get mobil TDT 5w40. i wish i could use the same in the A4 but it's not 502.
i would certainly consider GC if there's one on the spec sheet that i can order online.
Thanks all.
Thanks all.
