Be careful using an automotive filter. Not all automotive filters have built in bypass valves. And most small engines don't have internal bypass valves. If using an automotive filter, make sure it has a bypass valve.
Note: All the filters mentioned in this thread, the 3600, 3614, L10241, L, FL400S, 51348, 51773, 51056, 51396, and PF2 have bypass valves and should be fine.
