GC is quite shear stable, not many UOAs I've seen show much viscosity reduction of GC that couldn't be attributed to fuel dilution. They might be out there, but I haven't run across them. I think my BMW thinned GC about 0.5 cSt, I'd have to look. Even just in my car I've sheared the [censored] out of M1 0W40, for instance.
Rotella 15W40 may be more shear stable than the 5w40, you'd have to search for every UOA you could find and see if there's a pattern. Not many people (myself included) bother to spend $20-$30 on UOAs for yard equipment.
Based on the Amsoil ASE product, I bet there are a lot of group IV 10W30s out there that actually have no VIIs but aren't marketed as such. M1 HM 10W30 may still have no VIIs. It seems like M1 "isn't what it used to be" in some of the grades, I'm not sure if the current 10W30 would have no VIIs or not. Anything with "energy conserving" on it these days doesn't give me a warm feeling.
Perhaps you could use the VI (not VII) rating from ASE specs and compare that to other 10W30s. When you find one that is similar or lower it may have no VIIs. That's not a guarantee though.
On whether air cooled engines actually shear oil - that seems to be the indication and the primary reason for consumption. The engine shears it, it thins out, and goes right past the rings. In the process it fouls the rings and the problem gets worse.
Esso XD-3 reference:
here
Rotella-T reference:
here
Amsoil ASE reference:
here
The VI of ASE (confirmed no VIIs) is around 146 and AFAIK it is group IV (PAO).
You'll see that XD-3 15W40 is 140 while straight weight SAE30 is 108. I believe this is dino, not synthetic base. One could guess that VI=105 may be no VIIs in dino base stock, and ~145 is no VIIs in group IV basestock.
XD-3 0W30, for instance, has a VI of >165. It is group IV and VIIs have likely been used as 165>145.
Rotella-T 15W40 has a VI of ~140 and is dino, so probably has VIIs. I didn't find a product sheet for Rotella-T SB 5W40, but found
this . It shows a VI for 10W40 of almost 172. I believe this is group III basestock, but will likely be corrected.
Of course some VIIs are better than others so some oils are more shear-stable than others.
M1 10W30 data sheet is
here and it shows a VI of 140. Depending on the basestock this may be good. If group III there may be VIIs. If group IV then it may be VII-free.
M1 10W30 HM data sheet is
here . It's VI is 145. It's been said that the HM and EP products are stouter than the traditional products, perhaps the EP products have higher grade basestock and the 10W30 grade still has a VI in the 140s. Of course 10W30 EP may cost more than Amsoil ASE but hey....
