Originally Posted By: Craig in Canada
I have MTF in my 1998 528i (ZF 5 speed) right now. I had a fill of MTL only last one year (15,000km) and become notchy. After changing it with MTL it was still notchy. I tried D4ATF and it was sort of smoother in some conditions, but still a little off. Amsoil MTF is perhaps a little better yet.
I think my notichiness is actually wear in the shifter mechanism which I'll be addressing when warm weather comes my way. The same could be true for you and fluid won't help. I will hold further judgement on MTF until I make sure that the linkage isn't the issue. I'm "mildly" concerned that Amsoil "corporate" does not recommend MTF for this transmission, but others (including Pablo) highly recommend it. I believe that MTF's viscosity specs are right in line and the like - hopefully there is no chemical incompatibility to be concerned with. Redline products far outweigh Amsoil in BMW gearbox popularity so there isn't a large community running MTF to query.
MTL did work well in my climate. When I first switched to MTL from D4ATF during the summer it shifted better than the thinner fluid. In cold weather, it's possible that MTL will be harder to shift than D4ATF until warm. MTL was also the first fluid to free my 5-th gear shifter gate stickiness in extreme cold (a documented problem with some ZF 5-speeds).
I also used Synchromax and wasn't particularly impressed. It didn't improve shifting at all over D4ATF and was VERY thin, particularly when drained. I usually run gear and diff fluids 2 years and 25,000km (15,000mi) which is fairly short. IMO it's a little over-hyped by forums.
I've used: MTF-LT-1 (factory) -> D4ATF -> RP Synchromax -> D4ATF -> MTL -> Amsoil MTF
Yes, there is quite the following in the E36 community for Redline. I wish there were more users of the Amsoil MTF, but someone has to go first so I'll give it a go. It should handle my application better than the MTL does. I get a little seepage of MTL at the track, comes out of the vent hole. My guess is that I am getting it pretty hot and sloshing it around a lot.
