I just bought a 2008 Mustang GT with the 4.6L V8. Not exactly the same 4.6L engine as in your Grand Marq, but close enough.
I've been pondering this same issue for the past couple of months. I've done as much research as I can on this, and I am now convinced that the 5w20 spec is all about CAFE regulations. From what I can tell, Ford specs 5w30 for these engines outside of North America. That in itself is telling.
Most 5w20 oils have HT/HS of about 2.65. Amsoil 0w20 has HT/HS of 2.8.
Most 5w30 oils have HT/HS around 3.1.
I personally feel more comfortable with a slightly heavier oil in my engine. Therefore I've decided to switch to Amsoil SSO 0w30 at my next oil change. It has HT/HS of 3.2, excellent flow characteristics, and incredibly high TBN for a gas engine oil. I don't have any particular loyalty to Amsoil, it's just that the specs for this oil seem to be better than all of the others. It's also more expensive.
I'm planning to run it at 7,500 mile OCIs while the car is under warranty along with a couple UOAs just to satisfy my curiosity.
My second choice would be Pennzoil Platinum 5w30 based on the good UOAs it's getting here.
