Hi, Bjorn,
Thanks for the info. I deleted the TXT SJ/CF specs from my chart since I no longer use that oil and it is not available here (Hawaii) anymore. I have only three liters remaining of what I think is the TXT SL/CF oil. Its specs are somewhat different: kinetic viscosity at 40 deg C = 85 cSt and at 100 deg C = 14.2 cSt, with PP = -31 deg C. I'll use up the last of this oil, along with some 5W-30 Castrol SLX OE Pro, in about 5000 miles when my next oil change is due. Incidentally, the newer TXT is no long available here, either. The VW dealer stocks only the Castrol SLX for 505.01 use now. Once my TDI PD is out of warranty I expect to start using Valvoline Maxlife Synthetic 5W-30 which is allegedly 505.01 compliant. But that's 15000 miles away. . . .
Cheers, Mark
Cheers, Mark
