AT spec. 3309
Here's a good cross-reference list for the stuff. It's used in Ford Fusion V6 six-speeds and the cousin Mazda6, both of which use the AW trans. My research suggests that its all ExxonMobile-sourced 3309 from ExxonMobile Canada. The stuff was readily available at my Ford dealer. I understand that substitutes are not recommended based on the friction materials used in the AW transmissions.
http://www.mazda6tech.com/tsb/aisinwarner.pdf
Originally Posted By: Johnny
Thanks SamSnyder. A memo straight from the mfg. I would say these are the products to use.
Yes they are the ones to use but aftermarket fluids that list the spec such as T-IV are fine.
