Originally Posted By: tpitcher
On my '03 GMC Sierra that has 124k on it Should I bleed the original DOT 3 Brake Fluid and put in new or just leave well enough alone...??
I used to have a 2000 GMC Sierra. If you drive in winter with road deicing - salt - pay attention to the rear calipers. They tend to stick unless you clean and lube the caliper slide pins
Not sure if 2003 or 2004 was when GM went back to drums on their half ton trucks. The drums have far fewer issues
To flush the brakes, use something to slurp the old fluid out of the reservoir. It's difficult to get out all of it though, there are little plastic baffles that prevent you from reaching every corner of the reservoir.
Have a helper step on the brake pedal while you start at the rear right, open the bleed valve and let the fluid go out. It will take some time and quite a few brake cycles until clean fluid comes out
Note: keep an eye on the reservoir level and make sure to keep it topped off. You do NOT want to run the reservoir dry, that will ruin your day
Most modern vehicles with ABS can still be bled/flushed the old fashioned way, or with minor modification to technique, and without the need for a scantool.
For example, my ’07 FJ Cruiser has electric assist brakes. If you follow the shop manual, you do NOT pump the brake pedal while flushing: you keep firm/steady pressure on the pedal while the helper opens the bleed valve
The +04 Prius is another animal. It also has electric power assist brakes, but uses solenoid valves and a “stroke simulator valve” to properly route brake fluid and work with regenerative braking. In that car, you MUST use the dealer scantool to properly bleed/flush the brakes, or they stop working
If in doubt, you can purchase a subscription to an online shop manual source. Toyota charges $10/day, and in that time you can download everything you need. Another source that I use is All Data DIY, you purchase a yearly subscription. Well worth the minor cost if you have any doubt or concerns!
