M1 0W40...GM 6.0L....24,000 miles OMG!!!
I'd like to see the oil filter cut open. I don't think Amsoil is the way to go. The cooling system needs to be pressure tested. Then any leaks need to be fixed. I needs short oil changes till then. None of this will happen with a clown like this guy. He'll have to replace the engine. Then he'll post online about what a piece of junk GM trucks are.
They are on the verge of repo'ing the truck,found that out over wings & beer thursday. I'm not lifting another finger for this rig.. I was hoping to pass along some useful long term numbers but...
Originally Posted By: Cutehumor
......... I'm not sure if GM would honor the warranty on this vehicle even if you took it in for warranty repair. .........
I think Warranty is only up to 36,000 miles, not 80,000
Originally Posted By: REDDOG
How many miles ago do you suppose the Super Tech oil filter went into permanent bypass?
REDDOG
The oil filter for the GM trucks don't have a bypass. The bypass is in the block, and I bet it's stuck in permanent bypass from sludge.
Originally Posted By: chet2
now this is my type of dude...2 quarts low on a big engine and 3 oil changes...totally indifferent..and yet if he had sprung for 8 xtra oil changes for 200$, engine would probably be fine...cant be bothered...or even add oil...i bet there wouldve been less damage if he had maintained the oil level
And just think, he's a HVAC service person. What do you think his work looks like? It's called job security. Do [censored] work so you get called back. Must be a union man.
You should give the finance company a copy of the oil analysis. But they wont care. They will just sell it to some poor sucker.
Shoot, and I was just going to say I would provide the SSO and filter for this experiment.
I looked at an old UOA of a 1990 Taurus with 24K+ on the Amsoil ASL and its better than this one.
Iron = 123
Lead = 96
Copper = 20
Aluminum = 12
Silicon 31
TBN = 3
Visc100 = 15.74
This engine had an Amsoil SDF34 filter at 74K and 92K and changed at 99K.
I doubt the oil was low to any great extent in this Taurus.
So what to conclude?
Amsoil ASL better than Mobil 1?
Filter changes are needed?
I don't beat my vehicles?
With an unknown future and any problem with the engine not going to be fixed,why waste good money on an oil and filter for skewed results.. I may try the SSO in my daughters Aveo,at least I know it'll be looked after.
