Originally Posted By: JohnBrowning
First the 4.7 does not have a sludge problem do some home work instead of listening to idiot on the WWW! It is a white foam like mix and it is simply a matter of oil mist and moisture geting emulsified and settleing at the higher point. To add insult to injurt the fill tube is made out of a composite material that heats and cools drastily differently then the surronding area. Then it is also a long and well above the rest of the hot engine parts. I have had 4.7's open for perfomance modifications and have never seen anything remotly like sludge and have never even seen the foam any place other then the fill tube. Then on top of that they have a blocking device that will hide that foam from view tha has been included on all of the 4.7's since 2001. You see this same thing occur on Topyota's 4.7 and manyof the Daimler Benz engines.
Thankfuly for use the 5.9 has been left to history and the new Hemi has replaced it. The 4.7V8 is an excellent engine. It has low wear numbers and has very few failures or problems. The gaskets are good and the seals are good and the design and materials are great!
The 4.7 likes just about anything from 5W30 to 15W50 with no problems. Obviously some common sense is needed to select the right grade based on ambient temp.'s! I have no experince with anyone running 5W20 wich I am sure is probably now the recomended oil. My Dakota like just about anything I put in it. The time for oil pressure to come up to full pressure was the same in the summer with M1 15W50 as it was inthe winter with M1 5W30. I found that if I ran synethic oil and did mostly highway driveing I never had a problem with the foam. When the wife was useing it for mostly around town driveing lots of short trips the foam would appear. It was worse with dino then it was with synthetic.
I am sorry to continue this but you are WRONG! I even posted links to SLUDGE problems with the 4.7L. Yes, the white mayo like stuff is not sludge as we usually describe it. As I said it is just a part of the sludge problems with the 4.7L and is caused by condensation. I have seen pic's on Dodge forums where the VC's are removed on 4.7L's and the entire top end is covered in the condensation mayo like substance. I brought it up so he could look for that not too imply that was the actual sludge issue.
However, the 4.7L's have had problems with internal/lower end sludge if describing it like that makes you happier. Lots of 4.7L's have eben blown because the lower end got so sludged up the pickup screen got clogged. Man it is everywhere on the net from owners with blown 4.7L motors due to sludge. Read some of the links I gave rather than tellling others they are wrong.
No one said the 4.7L was a bad motor, mine was actually a very good one, but for you to tell people it never had a sludge issue is absolutely wrong. It did and especially in the early to mid 2000's. Also, 1st you tell people to look on the Dodge forums to prove they don't have sludge problems then when I post links from said forums( and elsewhere )showing they do, you say not to believe what you hear on the web. So which is it?
The 4.7L is prone to sludge issues even in engines that are cared for properly. Fact not fiction and the proof is out there even if you have never personally seen it. Again, check the links I provide or do a search for "dodge 4.7L sludge problems" and sit back and read for days.
