Originally Posted By: Andrew
I have read about 100 internet discussions about T-IV as I also have a Corolla auto. What I have gained from all of them can be summarised as follows:
- T-IV is the Toyota branded ATF that meets the JWS3309 spec for Aisin Warner transmissions. This is most likely rebadged Mobil 3309 ATF. Mazda, Saab, Volvo also have rebranded ATFs for their Aisin Warner transmissions. Mobil 3309 is only available in bulk so for a Toyota, the risk-free option is T-IV ATF from the dealer. It is relatively cheap.
- T-IV is at best a mineral ATF and works well in Toyota autos that require it. The only caveat on this is that generally the small fours transaxles are quite hard on the ATF and the Toyota service schedule for the tranny is probably a bit too long. If you do regular drain/fills using the drain plug on the Corolla transaxle, you will not have a problem with T-IV. I do drain/fills at every scheduled service and the fluid costs me approx $AU 25
- There are other boutique ATFs that are recommended for use in transmissions requiring T-IV. However, they do not meet JWS3009 and so technically will void warranty. It is debateable whether this would ever be detected or enforced by the manufacturer should a manufacturing fault occur. However, if you want to go to a boutique or synthetic ATF, which seem to work as well or better than T-IV and allow longer drain intervals, the safe bet is to wait until after warranty.
What is your tranny fluid change interval? Is there any synthetic fluid in the T-IV at all, or is is all conventional? Would you ever switch to Amsoil or equivalent after your 60K warranty is over? How many drains and refills do you do to get most of the fluid out?
