Originally Posted By: dailydriver
Originally Posted By: Colt
The traction would awful in snow.
Also the rubber hardens with cold weather causing less traction even on dry ground,faster wear and less effective braking.
Not just that, but one can actually freeze the summer rubber compound (in a cold enough winter) rendering VERY expensive tires useless even once they are used in the late spring/summer.
In other words you can freeze/heat cycle the grip right out of them!!!
REALLY??!!!?!? Im thinking of buying summer tires for my saab, since I have winter tires, so dont necessarily need AS tires for the warm weather.
However, Id keep my summer tires outside (wrapped) or in the garage in the winter. If I can't do that (because it can potentially be in the teens or single digits for long durations), then I may have to re-think.
Thanks,
JMH
