What are your opinions on using a top engine lube after using a system cleaner? After using V-Power system cleaner (or any of the others), and then using a full tank with nothing added, I am thinking of using MMO on the third tank to lube the fuel pump and injectors. From a couple of sources, I heard that Toyota fuel pumps wear faster than others and think that MMO would help after running a cleaner.
I only run system cleaners when I am taking a long trip that will empty the tank within a day or two. I have been doing this for years because I don't like to have the cleaning chems sitting in the tank working away at the seals and moving parts. Now I am thinking of adding the MMO step.
Thanks.
Thanks.
