Originally Posted By: marto_ca
Nice thread here. So about the cleaner, can I use a regular dose right after I've changed the oil, or would that put [censored] in my oil for the next 8-12 months, when next oil change is due?
I don't see how that would happen over 8-12 months. If the PI gets into the oil, it will be within that tank of fuel.
Here's the recommendation:
Quote:
Treat one full tank of gas every 4,000 miles or 100 hours of service. One bottle (12 oz) treats 20 gallons of gas. Do not treat and run more than 40 gallons of gas per treatment.
As long as you don't exceed this (even for a short drive) you should not get much PI in your oil. I put a bottle in less than 5 gallons of gas and this is NOT recommended - I could smell the PI in the drained oil.
So just make sure you have 10 gallons of gas in the tank and use 1/2 bottle, for example.
