Originally Posted By: Pablo
Originally Posted By: NHSilverado
HMM? Amsoil making claims about the competition making an inferior product. Who would have ever believed it.
RP MaxGear is excellent gear oil. Amsoil needs to spend more time worrying about their own product and less time making statements about the competition( that many times are false or misleading ).
Amsoil made no claims. They did the research and published the paper. If there was some erroneous "false" information contained in the white paper, please let me know. Sounds to me, as if you haven't actually read the paper:
Amsoil Gear Oil Paper
Amsoil absolutely made claims. That is the entire point of the study and their conclusions. Amsoil is "claiming" things based on the results from the lab they hired and results from their in house tests done during the study. Only if that lab did this on their own, and did 100% of the testing, and then published the results themselves would Amsoil not be claiming things. They are here however.
In questioning the validity of this study I would start 1st thing by asking "why was part done in house and part down out source"? If you are trying to play the "independant lab testing" card have it 100% independant. Also, I place very little credibility on tests that are paid for by a fluid mfg know for shady practices even when done by outside sources. A TRULY independant test is one run by an outside sopurce on their own or commissioned by a company without any of their products involved. It is not really independant when you pay for it and YOUR product is in it.
Actually, there are some questionable claims in the paper. Have YOU actually read it? Amsoil claiming one set of things that is completely different from the test data RP provides. Who do you believe? The company making it or the competition who has a reputation for false and misleading statements about their own products as well as their competitors products? I know who I will believe.
I was in the process of listing the discrepencies I found( had my 1st post up in edit )when my dog got sick and had to be rushed to the emergency vet. By the time I got home I decided to forget it. The second after I posted the 1st time I knew an Amsoil pimp would jump it so I was going to back it up. Guess I betetr so here goes...
On the ASTM D-2270 Viscosity test both Amsoil & RP = 165( high # is good )
I don't know enough about the J306 test to comment on what it means and RP does not provide enough data to compare it to what Amsoil claims. That one you have to just go by what Amsoil says. They say RP failed.
I am going to contact RP and see what they say when I have time.
On the low-temperature viscosity/Brookfield Viscosity Test (ASTM D-2983)There is a MAJOR difference between what Amsoil claims and what RP claims. Based on false claims about an RP product by Amsoil in the past I will believe RP. Using RP's #'s they actually do better than Amsoil. SAE 75W must be less than 150,000 cP at -40°C (-40°F). Amsoil comes in at 68,150 and claims a ridiculously bad 389,500 for RP. RP claims a 59,911.
Amsoil then makes this statement...
Originally Posted By: "Amsoil"
Royal Purple and Lucas failed the cold-temperature Brookfield requirements for 75W gear
lubes, as well as the high-temperature requirements for SAE 90 gear lubes, effectively disqualifying them entirely from the
SAE 75W-90 category. Royal Purple Max-Gear, having also failed the Shear Stability Test, was the only gear lube to fail
every parameter of the SAE J306 requirements
I say Bull. I can't contradict the J306 test because RP doesn't give the data but they did better than Amsoil in the Broofield test. Sounds like more false and inaccurate statements by Amsoil about the competition which they are famous for.
In the standard pour point test method(ASTM D-97)Amsoil claims a -37 pour point for RP when RP claims a -40. Not a huge difference but once again Amsooil making a false( IMO )claim. They claim a lower pour point for their product of -50. They then go on to say...
It is important to have a low pour point combined with a low Brookfield viscosity value since it is possible to have a good low pour point but only a marginal Brookfield viscosity. Castrol SYNTEC is a good example of this. SYNTEC had the best pour point of the gear lubes tested, but a borderline
Brookfield viscosity pass at 149,850 cP. Lucas 75/90 Synthetic, on the other hand, did not perform well in either area. It
showed a pour point of -37°C (-35°F) and a Brookfield viscosity of greater than 2,000,000 cP. AMSOIL Severe Gear 75W-
90 and Torco SGO Synthetic had the best combined Brookfield and pour point scores.
I would say that is false because they have the completely outrageous 300K Brookfield test data on RP. I highly question the accuracy of that test result. When you factor in RP's claimed 59,911 Brookfield teste result( which was lower than Amsoil )and a respectable -40 pour point test( again their test data better than Amsoils claim ), I would say RP was right there with them in this test.
Can't comment on the Oxidation testing as that data is not available on RP's site.
Next 4 are all related( (2)ASTM D-2783, ASTM D-3233, ASTM D-4172 ).
1) - 4 ball EP weld point. RP has the same test results in both data sheets( 400 )which is the same as the Amsoil.
2) - 4 ball EP load-wear index. RP tests low according to Amsoil. No data from RP to compare to.
3) - falex extreme pressure test. Yeah, okay, RP tested the same as the dino 80W-90's. Please. Can't dispute it of course as that is not data I can check but come on.
4) - 4 ball wear test. RP just below Amsoil. No RP data to compare.
* - so RP performs at the top in 2 but only slightly better or as good as 80W-90 dino on the others? Does anyone else find that hard to believe?
In the Copper Corrosion (ASTM D-130) test Amsoil claims RP fails the GL-5 portion but doesn't test on the MIL( ?? ). RP says they pass the copper corrosion test.
They even try to use Price as a test case in this paper. 1st of all pricing is very different depending on where you buy it. They have RP listed at $13.95 and their product at $11.75. What a JOKE! You can get RP MaxGear anywhere for $9.
In the end this test like all of Amsoil's( and Mobil 1 does it as well )"look how great we are" tests are slective tests chosen to pump them up while putting down their competition. This is not a unique thing to Amsoil or even the synthetic fluid market by any stretch but IMO it is sleezy.
There is also data on RP's site for their product never mentioned in this Amsoil study. So for all those who I just KNOW are thinking there is a reason( ie; it performed poorly so they don't want to admit it )why RP didn't have some of the data posted in this test for me to compare I can say the same about Amsoil. Where are these other tests and why were they not run? How many other tests did you run, that your product performed poorly in, so you didn't include that?
I would like to know how does Amsoil explain some of these very different results claiming poorer #'s than RP got( and one that was way off the chart and really questionable )? How do they explain a failing copper corrosion test when the mfg got a pass? If you are going to take Amsoil at face value on all their claims you have to do the same for RP. So, how does the big differences get explained? I know I have an opinion.
I am curious if Amsoil bothered to check the test results they got vs what the mfg of the other products got so when a huge difference occured they might have rechecked it for accuracy? Or, did they just say wahoo we can trash them now?
Another member summed it up about RP so very accurately...
Originally Posted By: "badtlc'
They are quality, American made, and I've never seen their marketing single out other oils to promote themselves. They are proud of their product and just want you to try it.
That is it in a nutshell describing the biggest difference between Amsoil and RP. Both make a great product but one mfg let's their product speak for itself while the other tries to tear down the competition to pump their product up. IF it is so good simply state that and leave it at that. The biggest Amsoil gripe I have is their sleezy underhanded tacticts and false and misleading statements like we see in this paper about the competition. If Amsoil published a paper saying the Sun would rise in the morning and set in the evening I would not believe it.
