Saw this in the last couple catalogs I received from them. Something called the Fitch Fuel Catalyst. Pretty much ~$200 to somehow re-refine your fuel. Never thought I would see Summit peddle this kind of garbage. Anyway, here is the description:
Get maximum performance out of your fuel with the Fitch Fuel Catalyst.
The Fitch Fuel Catalyst transforms gasoline and diesel into a superior quality fuel. Get more performance out of your engines for less--less money, less pollution, and less maintenance headaches. The Fitch Fuel Catalyst is permanent fuel treatment device that reformulates fuel, resuscitates partially oxidized fuel, and suppresses the growth of bacteria in fuel. Fitch Fuel Catalysts ensure that all fuel delivered to combustion engines is in optimal condition, allowing the engines to extract the maximum amount of energy with minimal emissions per kg of fuel. Once fuel has been refined, it sits in a holding tank, is pumped into transport vehicles, is shipped worldwide, sits in the holding tank at a gas station, and then you purchase it. That fuel refined as 93 octane has substantially lost its potency and freshness. The Fitch Fuel Catalyst helps return gas station grade gasoline or diesel back to its refinery-fresh state, for increased fuel economy and performance. Fitch Fuel Catalysts offer a better quality of fuel, which translates into better engine performance. The Fitch Fuel Catalysts are maintenance-free devices that are warranted for 250,000 miles. The Fitch Fuel Catalyst can easily be installed in the fuel line, much like a fuel filter, or directly into the fuel tank.
and the link:
http://store.summitracing.com/partdetail...15&autoview=sku
and the link:
