Got my Blackstone report today for my UOA on my Blazer. The truck has 25k on it and the oil was run 4,470 miles. This was from the last fill done at a Texaco Xpress Lube. I told them to use Havoline 10w30, but I don't know if it was bulk or bottled, and I assume it was pre-DS formula since it was put in 1-6-07. The gist of the report follows:
"Lead and sodium both read fairly high in this first sample from your Blazer. Lead is mainly from the bearings and could possibly be from a particle streak. If so, it's temporary and should drop next time. Sodium may show a trace of anti-freeze, and this could be causing the lead. But sodium can also come from additive in various types of oil (not Havoline), so we aren't going to call this a problem just yet. All wear other than lead looks great. If this engine sees a lot of idling or city driving, then that may explain some of the lead. The TBN read 2.2, on the low side."
This test/ Univ. Avg.
aluminum 2/ 3
chromium 1/ 1
iron 8/ 15
copper 5/ 5
lead 33/ 8
tin 0/ 1
moly 25/ 65
nickel 1/ 0
manganese 0/ 1
silver 0/ 0
titanium 0/ 0
potassium 1/ 7
boron 12/ 37
silicon 21/ 18
sodium 28/ 10
calcium 1985/ 1954
magnesium 20/ 151
phos 865/ 739
zinc 968/ 893
barium 17/ 0
This test/ Should be
sus visc 65.1/ 59-65
flashpoint 385/ >375
fuel % antifreeze % ?/ 0
water % 0/ insolbs % .3/
Since I changed the oil and filter myself this time, I know that it now is running Havoline 10w30 pre-DS. Any comments or thoughts on this UOA?
aluminum 2/ 3
chromium 1/ 1
iron 8/ 15
copper 5/ 5
lead 33/ 8
tin 0/ 1
moly 25/ 65
nickel 1/ 0
manganese 0/ 1
silver 0/ 0
titanium 0/ 0
potassium 1/ 7
boron 12/ 37
silicon 21/ 18
sodium 28/ 10
calcium 1985/ 1954
magnesium 20/ 151
phos 865/ 739
zinc 968/ 893
barium 17/ 0
