Originally Posted By: Kestas
I recently changed the transmission fluid in my neighbor's 03 Silverado with 50K. Changing the filter was nearly impossible, there's a crossover exhaust pipe that goes under the pan. The best I could do was drop the pan a few inches, slip out the old filter and slip in a new one. I couldn't clean the pan and magnet.
I believe it took me 14 qts until I was satisfied the fluid flushed out was clear.
Kestas,
Deeply respect your knowledge of bearings and most technical. This is the difference in professionals and hobby wrenches. At my shop that pan would have come off, reguardless of what else had to be removed/loosened to get to it. Had a customer in a month ago for trans service. Also a Chev PU, had to support trans so that rear crossmember could be removed to allow access to rear pan bolts. Guy's a truck driver, two weeks later when he was back home tranny gasket was leaking, pulled crosmember again and retightened pan bolts. Yesterday he was back STILL leaking. Pulled crossmember, pan and replaced gasket, poured her full of fluid, then apologised for all the inconvenience. Any other way to do business?
Bob
