Originally Posted By: rangerdood
My truck takes 5 quarts total, so I'm planning on 3 of 5w20, and 2 of 20w50. This should be just about right for this truck. Since they're the same brand, and same DepositShield line, I would imagine it should be fine to mix... It's not like they're going to stay separated in the crankcase.
No, at worst there is the possibility that the two oils each have symbiotic chemical constituents by themselves but that when they're mixed, the delicate symbiotic balance will be upset and there will be some reduction not in the effectiveness of the individual additives, but in some of the additional benefit resulting from the particular balance of different compounds.
I don't doubt there is some of that, but the era of truly incompatible oil additives, and real additive clash, is over as far as I can tell. In reality it doesn't seem to matter what oils are mixed: the oil functions as oil with the resulting properties would be predicted to function, meaning that the viscosity result is calculable and the performance results are perfectly in line with what that would imply. In terms of UOA or any other type of evidence as to actual performance, I have not seen anything that indicates that this has not been the case, even one time.
