Completing your 80% lower with a CNC Machine
by Merkava_4
05/25/16 07:33 PM
Motor oil Sale
by GuinnessGuy
05/25/16 07:26 PM
If Homer Simpson had a Soldering Station...
by Merkava_4
05/25/16 07:17 PM
Peerless/Tecumseh 205-024c
by ford46guy
05/25/16 07:02 PM
Clever Tire Mounting Machine from Corghi
by SubLGT
05/25/16 06:15 PM
Help - transmission filter does not fit the slot!
by 69GTX
05/25/16 06:06 PM
New Browning Buckmark
by billt460
05/25/16 05:54 PM
Signature Limits?
by 2015_PSD
05/25/16 04:48 PM
pistol grip shotgun wanted
by FirstNissan
05/25/16 04:14 PM
microGreen Memorial Day Sale
by DBMaster
05/25/16 03:18 PM
Biomed Tech internship - Osceola, FL
by Mr Nice
05/25/16 03:06 PM
New Car - First OCI Subaru Outback
by Oldswagon
05/25/16 02:43 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
108 registered (4WD, 2KBMW, 901Memphis, 04SE, 69GTX, 97prizm, 13 invisible), 1736 Guests and 326 Spiders online.
57973 Members
66 Forums
249402 Topics
Page 1 of 2 1 2 >
#1084725 - 02/12/08 04:09 PM (Z)-Octadec-9-enylamine fatty amine
JHZR2 Offline
Loc: New Jersey
I just bought a quart of VW Part number G 070 726 A2 - the part number that is specced for MT fluid for a 2008 VW rabbit.
On the bottle, it explicitly states that it contains (Z)-Octadec-9-enylamine, as it has a warning not to get same on the skin. I did a quick search, and this is a fatty acid amine.
it is a molecule that looks like this:
Background info is as follows:
PHYSICAL STATE clear to slight yellow liquid
MELTING POINT 17 - 27 C
BOILING POINT 348 - 350 C
SPECIFIC GRAVITY 0.813
VAPOR DENSITY 9.22
NFPA RATINGS Health: 3; Flammability: 0; Reactivity: 0
FLASH POINT 170 C
STABILITY Stable under ordinary conditions
APPLICATIONS:
Application of Fatty Amines
* Cationic surfactants (disinfectants, fungicides, germicide, leveling agents, hair rinse bases, wood preservatives, textile softeners, dyeing auxiliaries, ore flotation. pigment grinding aids. anticaking agents)
* Amphoteric surfactants and Amine oxides (antistatic agent, textile scouring agent, ingredient for low irritation shampoo, liquid detergent, foam booster, oil recovery agent)
* Corrosion inhibitors and asphalt emulsifier
* Dispersants, lubricants, water treatment agents.
Fatty amine products are used as a dispersing agent or internal/external lubricant for benefits in polymer production of to facilitate and stabilize the dispersion of solid compounding materials to enhance processability, to decrease friction and abrasion of the plolymer surface, and to contribute color stability and corrosion prevention.
Members of Fatty Primary Amines
* Octyl amine ( CAS RN: 111-86-4)
* Lauryl amine ( CAS RN: 124-22-1)
* Stearyl amine ( CAS RN: 124-30-1)
* Oleyl amine ( CAS RN: 112-90-3)
* Tallowamine ( CAS RN: 61790-33-8)
* Cetylamine ( CAS RN: 143-27-1)
* N-Tetradecylamine ( CAS RN: 2016-42-4)
* Cocoamine ( CAS RN: 61788-46-3))
* Hydrogenated tallowamine ( CAS RN: 61788-45-2)
* Alkyl(C16 and C18-unsaturated) amine ( CAS RN: 68855-63-0)
* Alkyl(C14-18) amine ( CAS RN: 68037-91-2)
* Alkyl(C16-22) amine ( CAS RN: 68037-92-3)
* Alkyl(C8-18 and C18-unsaturated) amine ( CAS RN: 68037-94-5)
* Alkyl(C12-18) amine ( CAS RN: 68155-27-1)
SALES SPECIFICATION
APPEARANCE: clear to slight yellow liquid
AMINE CONTENT: 200 - 215 mg/g
COLOR, APHA: 80 max
ALKYL CHAIN DISTRIBUTION:
C18 80% + C16 15% + C14 4% (Typical)
Edited by JHZR2 (02/12/08 04:20 PM)
#1084728 - 02/12/08 04:12 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: JHZR2]
JHZR2 Offline
Loc: New Jersey
#1084730 - 02/12/08 04:19 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: JHZR2]
JHZR2 Offline
Loc: New Jersey
Oleylamine
RN: 112-90-3
MF: C18H37N
MW: 267.49848
bp (C): 147 (p=2 torr)
mp (C): 15 - 22
density: 0.81
#1084825 - 02/12/08 07:04 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: JHZR2]
MolaKule Offline
Loc: Iowegia - USA
And the question or comment is?
"You are free to choose, but you are not free from the Consequences of your choice." Dr. Laura. smile
#1084919 - 02/12/08 08:42 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: MolaKule]
JHZR2 Offline
Loc: New Jersey
whoops... I was interested in the fact that it actually explicitly listed a specific molecule that is utilized in the formulation, right on the label.
I guess the question is, given the uses of this compound, many of which are listed above, which do you think it is performing in a "75W" gear oil? How does this fatty amine compound compare to the current state of the art for the function it is being utilized for?
Thanks,
JMH
#1084920 - 02/12/08 08:46 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: JHZR2]
bruce381 Offline
Loc: Millbrae, CA
I'd say friction modifier
bruce
#1084927 - 02/12/08 09:00 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: bruce381]
MolaKule Offline
Loc: Iowegia - USA
I'd say what Bruce said but add it is probably a multifunctional anti-oxidant/anticorrosion/friction modifer.
Current state of the art? No problems. Probably keeps the TAN stabilized while providing friction modification.
#1085057 - 02/13/08 12:52 AM Re: (Z)-Octadec-9-enylamine fatty amine [Re: MolaKule]
jaj Offline
Loc: Vancouver, Canada
If all the qualified chemists are guessing then the stuff probably has no function other than to act as a dispersant for some active ingredient that keeps falling out of solution and collecting on the bottom of the bottle in shipment and storage. If it actually was a super-duper component of the lubricant package, they wouldn't name it.
I think it's like the chemicals in food packaging - anything that is important to flavor is a secret - preservatives are listed for all to see!
Edited by jaj (02/13/08 12:54 AM)
#1085114 - 02/13/08 07:00 AM Re: (Z)-Octadec-9-enylamine fatty amine [Re: jaj]
JHZR2 Offline
Loc: New Jersey
this came from an imported bottle of gear oil. The european requirements for disclosure may be significantly different from ours.
As mentioned before, it was just interesting that they actually listed the presence of a technical molecule used in the formulation. Besides, say, an aliphatic hydrocarbon, which could easily be picked up in a GC-FID analysis, I doubt that much disclosure of any sort of formulation bits and pieces are really given in most formulations.
JMH
#1085166 - 02/13/08 08:44 AM Re: (Z)-Octadec-9-enylamine fatty amine [Re: JHZR2]
oilyriser Offline
Loc: Ontario, Canada
Add an oxygen to the carbon next to the N, and you get a psychoactive substance - oleamide.
#1085428 - 02/13/08 05:59 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: oilyriser]
Steve S Offline
Loc: East of IGO
Is that good ?
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1085430 - 02/13/08 06:03 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: MolaKule]
Steve S Offline
Loc: East of IGO
Chem 101 guess friction modifier or disperesant The molecule looks like my driveway.
#1085542 - 02/13/08 08:24 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: Steve S]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Is that good ?
http://jpet.aspetjournals.org/cgi/content/abstract/299/1/332
http://en.wikipedia.org/wiki/Oleamide
#1085630 - 02/13/08 10:53 PM Re: (Z)-Octadec-9-enylamine fatty amine [Re: Pablo]
Steve S Offline
Loc: East of IGO
Is that good ?
Pablo ,I am not exacty sure about it but it sounds good???
#1085718 - 02/14/08 06:56 AM Re: (Z)-Octadec-9-enylamine fatty amine [Re: Steve S]
John K Offline
Loc: Loveland, Ohio
I don't know if I should be impressed with all this chemistry data or doze off like I tended to do in my Organic Chemistry classes eons ago........
Page 1 of 2 1 2 >
