A CBR1000RR?
Yeah, first, if you don't have an aftermarket exhaust, you will probably ruin the cat like someone posted.
What are you trying to accomplish? More power? A common leaded racing fuel for a car, be it VP fuels like C12, C14, VP110, Power Mist T111, T112, Cam 2, Turbo Blue, etc...
If you ran it straight, compared to pump gas, you're probably not going to gain power. Most likely, you'll have a decrease on top. Might clean up some of the lean conditions at middle RPM's because of the lighter specific gravity.
What we've found from experience on a road course is that if you want to make a little mix of some fuels four your bike, a mix of about 3 gallons of pump gas to on gallon of leaded racing fuel will give you an overall improvement. The fuel doesn't need more octane, but the leaded fuel will add a little lead that improves the front of the combustion while also adding some aromatics into the mix also.
This will work on 1000/4's, 600/4's, 750/4's. If you get into an RC51, the Superhawk, Ducati 999,998, 749, 748, the size and shape of their combustion chambers can be a bit different in their needs depending upon their state of tune. Sometimes they will react better with more octane.
