Originally Posted By: Vaca
I agree generally that keeping the air intake passage clean is a good idea, and this certainly includes the TB and the butterfly, etc.
But so long as the deposits don't cause anything like the butterfly or the idle air control valve to stick, then why really care about the deposits? I can't imagine deposits to really impede air flow, unless the deposits are ridiculously bad...also, if the deposits get ridiculous, you wouldn't want a chunk to fall off and get drawn into the combustion chamber....but short of major deposits, I can't see what difference it makes to clean it or not.
My wife's old Expedition randommly stumbled & died at idle a few times shortly after we purchased it used with 65k miles on it. I checked the throttle body around the butterfly, and found it to be dirty, but not DIRTY. I cleaned it with carb cleaner, and never had the problem again. My theory: There was enough build-up to keep the butterfly from closing 100%, thus letting just a little bit too much air in for idle speed.
