Recieved two brand new BFG TA's today, with absolutely no markings for the high spot on the tire. (All tires I have bought in the past have had a white paint spot that's matched up with the wheel valve stem when mounting.)
However, these tires do have a 1 inch piece of plastic tape glued to the bead, with a UPC code imprinted on it.
Is this piece of tape a high spot mark? Should I align the tape with the valve stem when mounting...?
Thanks,
TLR
Thanks,
TLR
