Originally Posted By: Johnny
Originally Posted By: turboaccord1
ive never used a high mileage oil, what are the advantages?
Usually a little thicker base stock to help with blow-by, a few more detergents to help clean a little, some seal conditioner to soften old hard seals (usually some type of ester).
There u go Johnny...u got me 2nd guessing my decision to switch my '98 360 Jeep w/ 178k to YB HM. I had been using M-1 HM 10w30 and decided that a dino HM might be better & more cost-effective choice since the vehicle is now only driven a few thousand miles per year. But you got me wondering if M-1 HM is still the better choice. I wish they made PP in HM formula with more ZDDP, ester, etc., etc...
Since we are talking about Mobil 1, I will tell you of my conversation I had with them last week. I was inquiring about some products for my recently purchased Jeep Wrangler that now has 3,300 miles on it.
Question: Which Mobil 1 product do you recommend.
Answer: Regular Mobil 1 unless I plan on extending oil changes to 15K, and no need for high mileage oil if I start out on Mobil 1.
Question: Can I use Mobil 1 ATF in the automatic transmission & transfer case.
Answer: After being put on hold (I assume to either look in his book or ask someone) the answer was yes I could.
Question: Can I use Mobil 1 LS75W90 in the front & rear differentials.
Answer: Yes I can, but I would need to add the requires LS additive from Mopar.
Question: I thought your 75W90 had this additive.
Answer: It does, but not enough to meet Dana specs. Add the Mopar stuff.
Question: Can I go longer than the recommended 12K without changing out the gear oils if I use Mobil 1 LS75W90.
Answer: No. Do what Mopar recommends.
I left the conversation at that and thanked him for his time.
And I can tell you this is a raging debate over on the Jeep forums. Maybe the M-1 guy did not know what he was talking about, or maybe M-1 gear oil has much less additive than Royal Purple. But most people over there agree that Royal Purple has enough additive so that you do not need to add the Mopar stuff too. As a matter of fact, by adding the FULL recommended amount of the Mopar stuff to gear oil that already has LS additive, you run the risk of using too much and then your posi unit will not lockup like it should when in slippery conditions or even slip too much and cause the clutches to burn up sooner. This happened to me Johnny...
The proper way to handle the LSD gear oils is to not use the Mopar Friction Modifier unless you get chatter...then if you do, only add it in small increments until it is working as it should. Say maybe 1oz increments or maybe even up to HALF the recommended amount when adding to RP or M1 gear oils that are already formulated for LSD but you still are experiencing chatter...but MOST will say (at least with RP brand), that you rarely have an issue to where the Mopar stuff is required...Again, I am not against adding it, but you just do not want TOO MUCH LSD additive and you must assume that when using a gear oil that already has it, why would you need the FULL amount.
I am disappointed in the Mobil-1 support guy you spoke with for not elaborating more.
