Well, the owner's manual says dexron II or Type F. The factory manual called for Type F. On the dexron III it said replaces Dexron AND Mercon (I believe) I and II.
THis is for the power steering and I siphon with a hand pump because I can't imagine there being a drain plug. Run it for however long and pump out about a cup or two each time and compare to fresh fluid which resembles some strawberry syrup in the kitchen. Or Koolaid if you don't judge viscosity/fluidity/pourability/syrupy/thick......what is the word here??
