Originally posted by Kestas.
"Just about all drum systems are now servo type. The non-servo type does not have any self adjusting mechanism and has to be manually adjusted every so often. I haven't seen that design since my 85 Omni"
I have news for you. When I pulled the rear drums off my 2006 Sierra 1500 for a clean/lube, I was shocked/disappointed to find that the the brakes were not servo but the old leading/trailing shoe type. I expect that the primary shoes will wear out faster on my truck, unlike the servo type brakes where the secondary shoe does the majority of the braking and wears out faster.
There brakes are self-adjusting but the adjusters are not at the bottom like on servo brakes but on the strut at the top that goes between the two shoes. The two shoes pivot at the bottom on a fixed anchor.
Looking at the brake mechanism on my truck, it has just as many parts as a servo system has, so I just do not understand why GM went for this setup. Maybe the brake configuration is such that GM did not want the extra self-energising action with servo brakes.
BTW I manually adjust the rear brakes on all my vehicles twice a year(when I do the seasonal tire changeover) because the self-adjusters do not adjust till there is a lot a travel on the shoes. I can usually turn the adjusters about four clicks without the shoes dragging on the drums and end up with a noticeably tighter pedal.
