Seriously. I've changed tires on previous cars, but this one is weird.
My '03 Buick has the optional chromed wheels, and the manual doesn't mention them. Now each wheel has five chromed lug nuts that I presume are simply ornamental covers, and I can loosen them with my lug wrench . . . but then they won't unscrew completely. How can you get them off?
Further, they're within a central plate that looks like it might hide the actual lug nuts. Do I need to loosen (or can I remove?) all five chromed lug nuts, and then the central cover will come off? Or must I pry off the central cover plate -- and if so, how, without scratching the chrome?
I want to check the lug nuts on the wheels and tighten if necessary -- I'm getting a faint vibration while driving, mostly at low speeds, but possibly at higher (it's hard to tell with the poorly-surfaced roads around here). If all the lug nuts seem fine, then I'll have the balancing checked. (Plus I want to know how to do this, in case I have to change a tire sometime.)
Thanks in advance!
Thanks in advance!
