IIRC, there are two on each side (one is behind the motor mount), two in the front below the block/head interface and a couple in the back.
The ones in the back are only accessible once the engine/transmission are split.
To remove them, you need to punch a hole in them and pry them out. Or you can punch them in and then pry them out. Don't just push them in and leave them there.
Getting new ones in can be a challenge as they need to be hammered in. If the engine is in the vehile, the hard one would be the one behind the motor mount. I made a plate with the same bolt pattern as the motor mount and used the plate, a socket and bolts to draw up and press the plug in place.
It's strange, but I've only seen the side plugs leak. Very rarely have I seen the front and rear plugs leak....not to say that they don't.
