Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
biyogo, Jandry, BlueKelah, threeeightteen, TOADchunks
56891 Registered Users
55 registered (aquariuscsm, Atesz792, 2009Edge, B767capt, AlienBug, 04SE, 4 invisible), 852 Guests and 133 Spiders online.
56891 Members
66 Forums
244533 Topics
Page 3 of 3 < 1 2 3
#1196051 - 07/17/08 05:53 PM Re: Converting Used Motor Oil to Diesel [Re: cowhorse01]
Mobile_Oilguy Offline
Loc: Texas
Aggieland
Bryan/College Station Texas
#2153956 - 01/28/11 06:28 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
Norbert Offline
Loc: N.S.
Hi, I finished now my second refinery, this one is for continuously working. My problem is I cant get the diesel stabilizer Stabil AD 5300 and I need someone were can test my diesel.Has someone an Idee how to get to this stuff, the producer ( Nalco chemicals gives me no answer on my emails). If anyone working on a continuously refinery, you must be carefully!! The added oil has to be preheated to at least
180 C, until all water is for sure steamed out before the oil enter the system.
#2155165 - 01/30/11 02:53 AM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
Shannow Offline
Loc: Oz
You're having troubles with Nalco ?
I think that they think that they are rich enough ATM. Otherwise, they'd be collecting fish heads out of your trash to find a use for.
Nissan TD - Edge 5W30 A3/B4
L67 3.8 - Magnatec Stop Start 10W30
Mower - M1 5W50 with Rislone
#2305314 - 07/03/11 08:09 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
04SE Online   content
Loc: IL
How long before somebody shows up and tells you they want to tax your fuel?
2002 Avalon XLS | 118,000 | PYB 5w30 & TG3600
2010 CVPI | 105,500 | QSUD 5w20 & QS3614
#2364879 - 09/02/11 04:45 AM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
righteous Offline
Loc: ghana
how do you condense he vapoure in your distillation tank
please show me pictures of your babysit processor
what do ensure if i want diesel only at the end of my production
what difference lay between diesel made using used motor oil standard diesel in terms of qualities properties and performance
#2367964 - 09/05/11 01:31 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
simple_gifts Offline
Loc: Middlesex County CT
Lubeshiners...
2003 Echo >387K miles; Showing its age.
2006 B2300;101K;ALM
Less Melissa McCarthy and more Jenny McCarthy
#2535772 - 02/13/12 09:57 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
DIESEL_2500_2002 Offline
Loc: Utah, United States
What kind of Thermometer do you use, 700 to 1000 degrees? the auto ignition is only 750^F. When reaching those high temperatures do I need to worry about my tank blowing as long as I have no leaks, or will it not be able to reach enough pressure to worry about?
#3532166 - 11/07/14 12:41 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
TP4ME Offline
Loc: The Great Northwest
Would lower temps in a vacuum chamber be safer?
Page 3 of 3 < 1 2 3
