Last battery was Walmart Everstart 35
New battery is Walmart Everstart Maxx 35
Innocent enought?
The new battery seems to be taller and won't clear the battery tie down on a 95 Corolla. The back "hook" doesn't have enough length to reach the bottom plate and pass through the top metal tie for the nut. The front bolt is fine otherwise.
So I am thinking about just leaving the back unhooked and tie only the front. Not sure if it will cause long time vibration problem, but I have enough insulation on the top (+ plastic cap) that I am not worried about a short through the hood.
Innocent enought?
