Originally Posted By: GMBoy
Originally Posted By: XS650
Originally Posted By: BuickGN
Assuming the water didn't boil and you have an iron headed motor a short period at 230 shouldn't hurt it too bad.
Didn't hurt aluminum headed LT1 and LT4 Corvettes either, although it made the driver pucker up. The 2nd fan didn't come on until over 230F and they needed that fan in hot weather traffic.
It was an ugly way to do things.
Actually the fans come on at 228 degrees
On the scanner my TL only shows 187. The GN runs 160.
To clarify my other post, I meant that it's more safe to run the iron headed cars hot than aluminum. Didn't the LT1s have reverse cooling?
Yes they are reverse flow cooling. I've got a '94 LT1 vette.
What I was getting at in the reverse flow question is doesn't the coolant hit the heads first? If so, I could see it being able to run slightly higher coolant temps and get away with it. I'm just going off of memeory from a long time ago so I could be wrong.
