have two customers with shotmaking equipment. Both are taking my used wheel weights and making shot. So far, I've managed to get them to do it on the 1/2ves. Seems like a heck of a deal for me! As weights have to be melted and rim clips and other trash removed before it can be ingoted suitable to put in their electric heated shot formers. Electric is used to keep heat correct, then molten lead drips through a bolt with a specific hole size drilled through its center, then molten lead runs across an approx 1 inch lip before falling approx 6 inches into BRAKE FLUID !! In a 5 galllon bucket. Brake fluid provides slower cooling than water + high flash point and water soluible. Then shot must be washed to remove fluid, seived to remove most imperfect spheres. While w weights have value as salvage metal, a probably 150 lb 5 gallon bucket nets me approx 50 lb of near perfect shot. A few have "tails" and not quite round, but after a trip through setback,forcing cone,choke, factory shot is far from round when it leaves the bbl also. Wheel weight has higher antimony content than standard lead shot, but that only makes it harder (and slightly lighter) than factory shot. Certaily still not hard enough to damage barrel.
One shotmaker is a high score sporting clays shooter, the other is a 98% trap shooter. Both will use their shot when reloads are allowed.
Also have a couple guys who will occasionally cast pistol bullets on 1/2ves.
Bob
Bob
