I purchased a Ultrasonic Cleaner for the main purpose of cleaning AR-15 bolt / carrier assemblies. It works beautifully. After a couple of 8 minute cycles the entire assembly is all but spotless. I use water with some dish washing detergent added. My unit has heat, but I still heat the water in a kettle until it's hot to the skin. After I blow everything dry with compressed air and oil. It sure is a time saver. Ar-15's are beautiful guns, but a total pain in the a$$ to clean. This unit really helps. Bill T.
