I have a 2006 Ninja 250 that I have ridden only once since last May....when I started it up last month it ran like junk...needed to keep the choke on for quite a while. Once it was running somewhat steady it was fine as long as you did not give it gas in first gear...minute you turned the throttle it really weeezed and sputtered etc...
Now I know that if you leave the engines not run for awhile that the carbs have a habit of getting gummy and need to be broken down and cleaned(at least that is whet the dealer tech told me)
A friend of mine said he was having almost the same issues with an ATV...he said he added a bottle of a carb cleaner(he thinks it was STP) and that helped tremendously.....I'd like to believe that but I have my doubts
Worth a shot? I'd like to try some stuff before shelling out big $$ to have a bike wrench tear them apart.....
Goose
Goose
