MolaKule
Staff member
"Anybody have any pictures of synchros that dissolved due to GL-5? Didn't think so!
You guys are scared about nothing. GL-4 has plenty of sulfur in it as well, and the sulfur only becomes corrosive at temperatures over 250 degrees F. How many of you get your transmissions that hot? "
Most differential and Manual Transmission oils contain sulfur-phosphorous EP packages. GL4-rated oils contain about 40% to 60% of the amount; the other difference is the Friction Modifier.
Both differential and manual transmission fluids use chemical compounds that subdue or inhibit the corrosive effects of sulfur; calcium, magnesium, boron, potassium or other basic compounds. Emulsifiers, corrosion and rust inhibitors also are included to do their respective jobs.
Differential lubes use friction modifiers to reduce mechanical and fluid friction and add some anti-shudder friction modifier for limited slip, both very different chemical compounds.
Manual Transmission fluids use a different friction modifier for synchro engagement, a modifier that does NOT contain the same chamicals as differential lubes.
