So I changed out the Delvac 1 to try out this interesting Fuchs GT1 0W20. On initial observations the motor is about the same smoothness and noise. I've noticed that the idle MAF voltage has dropped a consistant 20mV compared to before, indicating there is less effort to keep the engine at 850rpm. Should be interesting to see how this zinc free 0W20 will hold up in the built 400hp SR20DET (2.0L 4cyl). Ive noticed that the engine feels a little peppier but I'm not sure if its the placebo effect? Anyways I'll continue to post my findings as there is clearly not enough people trying this oil!
http://www.fuchs-oil.com/index.php?id=742&type=1
One thing to note is that this oil is the darkest oil I've come across, out of the bottle!
