Hello, I just bought a car with a Chevy 383 Stroker motor in it and was wondering which oil weight you would recommend for it. I live in NJ and will probably store it in the garage over the winter, so it will probably only be driven early spring to late fall in the north east. Also would you use a different oil for storage then used for the rest of the year or should I just keep the same oil in it regardless so different oils aren't mixing? I was thinking either a 10w30 or 5w-40. I tried to do a search first but the search function doesn't seem to work so well for me. thanks for the help
Oh and any winter storage tips that you got are welcome also. I was going to just change the oil and check the coolant mixture, but leave the gear and trans fluid alone till the spring.
