Is there a preferred TPMS sensor these days - strap vs. the valve type. My previous 2 sets were using the band strap type. I've had one occasion where I band broke off in the wheel and another where a sensor was broken when either dismounting or mounting a tire.
With the valve type, it looks like the + side is that you can *drop* the valve when dismounting the tire by removing the external nut component of the valve which would allow for a easier method of dismounting a wheel.
I'm going to assume mounting is just as difficult - as in sometimes the case with a low profile tile/firm sidewalls.
Love to hear some feedback on the pros/cons of each sensor type as I plan to add sensors to my new wheels.
The ONLY + side I can see to the strap is working with wheels tha have the 90 degree bend valve to them, which makes it impossible to use the valve type tpms.
