I had some miscellany leftover from buying a junkyard transmission including a strut+hub assembly. Took the brakes off and the friction of the remaining wheel bearing is very low. Have been using it as a static balancer much like this snap-on device.
70-series tires balance great and don't often care if I stick the weight on the inside, outside, or split the difference.
60-series are a different story, and work okay in the rear, but shimmy a bit up front.
Tell me more about this "3 heavy spots" theory... could I for example split the difference, put the inside weight at 2 oclock and the outside at 10 and theoretically the "heavy side" is more "spread out"? And if it doesn't work, reverse the weights and hope it's better?
It may not have been said in so many words but you stick the tire/wheel on that snapon axle, spin it, watch the valve stem. If it stops in the same spot every time the top of the wheel needs weight added. I have found that it takes more than an ounce if the tire stops and reverses direction and less than an ounce if it just stops... but that relates to the friction in my own bearing set.
